Page 1 of 2
Software will not load <answered>
Posted: Mon Feb 04, 2019 5:32 pm
by Kutton
Came out to shop today and I kept getting message “power cycle acorn” which I did five times. Deleted software and downloaded fresh copy. Still same problem. Please help.
Re: Software will not load
Posted: Mon Feb 04, 2019 5:34 pm
by tblough
Are you sure you have communication with the Acorn? Heartbeat LED flashing? This is usually a sign that there is no Ethernet connection between the computer and the Acorn.
Posted: Mon Feb 04, 2019 5:36 pm
by Gary Campbell
This was also just posted. From Marty's Quick Tips:
viewtopic.php?f=61&t=1451
Posted: Mon Feb 04, 2019 6:01 pm
by Kutton
tblough wrote: ↑Mon Feb 04, 2019 5:34 pm
Pinged board and have communication.
Posted: Mon Feb 04, 2019 10:15 pm
by Kutton
Any one willing to help?
Posted: Mon Feb 04, 2019 10:17 pm
by Dave_C
Turn off your firewall and try again or make sure you have the proper exceptions to let CNC 12 thorough.
Dave C.
Posted: Mon Feb 04, 2019 10:18 pm
by Grifftek
I had this problem with a customers machine, worked perfect upon delivery, Customers computer expert updated windows, setup wifi internet and who knows what else.....
I had him follow the computer setup video so he could turn off all the stuff that causes problems, everything went back to working!
Might just double check the computer settings.
Bill
Posted: Tue Feb 05, 2019 12:35 am
by Kutton
Grifftek wrote: ↑Mon Feb 04, 2019 10:18 pm
Bill
Thanks will try
Posted: Tue Feb 05, 2019 9:59 am
by cncman172
Kutton,
Windows for some strange reason often turns on the Firewalls all by itself. Especially after updates, even some virus protection software and turn on the firewalls. Double check them because if they are enabled Acorn will not be able to talk to CNC12. You can add exceptions but the best way to do testing is to fully disable them in Windows.
Are you plugging your Ethernet cable directly from your PC to the Acorn, you are not connecting to a hub or ethernet switch are you? If so disconnect the internet and plug the Ethernet from the PC directly into Acorn.
Russ
Posted: Tue Feb 05, 2019 10:28 am
by cncman172
Kutton,
Watch this video from Marty and see if you have a static IP address configured in Windows for Acorn board.
Russ
Do this test!
