Software will not load <answered>
Kutton
Post by Kutton »
Came out to shop today and I kept getting message “power cycle acorn” which I did five times. Deleted software and downloaded fresh copy. Still same problem. Please help.
Re: Software will not load
Are you sure you have communication with the Acorn? Heartbeat LED flashing? This is usually a sign that there is no Ethernet connection between the computer and the Acorn.
Gary Campbell
Post by Gary Campbell »
This was also just posted. From Marty's Quick Tips: viewtopic.php?f=61&t=1451
Kutton
Post by Kutton »
tblough wrote: Mon Feb 04, 2019 5:34 pm Are you sure you have communication with the Acorn? Heartbeat LED flashing? This is usually a sign that there is no Ethernet connection between the computer and the Acorn.
Pinged board and have communication.
Kutton
Post by Kutton »
Any one willing to help?
Dave_C
Post by Dave_C »
Turn off your firewall and try again or make sure you have the proper exceptions to let CNC 12 thorough.
Dave C.
Grifftek
CNC Control System Serial Number: 0503160222
Post by Grifftek »
I had this problem with a customers machine, worked perfect upon delivery, Customers computer expert updated windows, setup wifi internet and who knows what else.....
I had him follow the computer setup video so he could turn off all the stuff that causes problems, everything went back to working!
Might just double check the computer settings.
Bill
Kutton
Post by Kutton »
Grifftek wrote: Mon Feb 04, 2019 10:18 pm I had this problem with a customers machine, worked perfect upon delivery, Customers computer expert updated windows, setup wifi internet and who knows what else.....
Bill
Thanks will try
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 »
Kutton,
Windows for some strange reason often turns on the Firewalls all by itself. Especially after updates, even some virus protection software and turn on the firewalls. Double check them because if they are enabled Acorn will not be able to talk to CNC12. You can add exceptions but the best way to do testing is to fully disable them in Windows.
Are you plugging your Ethernet cable directly from your PC to the Acorn, you are not connecting to a hub or ethernet switch are you? If so disconnect the internet and plug the Ethernet from the PC directly into Acorn.
Russ
cncman172
Post by cncman172 »
Kutton,
Watch this video from Marty and see if you have a static IP address configured in Windows for Acorn board.
Russ
Do this test!
