Checking Parameter 800 in a Macro File (Answered)
I'd like to check P800 (Fourth Axis Installed) in my CHCM.HOM file to skip the fourth axis homing routine if the rotary table is not currently installed. Unfortunately, it looks like the #800 series parameters are not mapped to the macro user system variables according to the 4.12 mill documentation.
9000-9399 Parameter values 0 - 399
9900-9999 Parameter values 900 - 999
Can I assume that #9800 - #9899 does actually have parameters 800-899 in them?
M92/Z
G91 G1 G20 Z0.120 F10.0
M26/Z
M91/X
G91 G1 G20 X-0.120 F10.0
M26/X
M92/Y
G91 G1 G20 Y0.100 F10.0
M26/Y
IF #50010 ; Prevent lookahead from parsing past here
IF NOT #9800 GOTO 1000
M92/A
G91 G20 G1 A30.596 F1800.0
M26/A
N1000
cnc_smith
Re: Checking Parameter 800 in a Macro File
Post by cnc_smith »
tblough wrote: Mon Jan 14, 2019 5:43 pm I'd like to check P800 (Fourth Axis Installed) in my CHCM.HOM file to skip the fourth axis homing routine if the rotary table is not currently installed. Unfortunately, it looks like the #800 series parameters are not mapped to the macro user system variables according to the 4.12 mill documentation.
I have attached a modified home program that I use to check to see if the 4th axis is turned on. I call my forth axis A. At M92 and the M26 all you have to do is change the axis label if you are not calling it A axis. Rename the file to CNCM.hom. This file was used on a mill and at the end it gives you the option to center the X axis. If is commented out.
This homing program looks to check the system variable for the 4th axis to see if it is turned on. If not it skips the homing of the 4th axis.
cncm 4th axis.hom
4th axis homing.
(575 Bytes) Downloaded 101 times
Dana
Thanks cnc_smith. I made one small change to your code. I used the axis variable name in the actual homing routines in case the axis label was not "A".
; Check for rotary table homing
IF [#20104 == 78] GOTO 1000 ; "N" for 4th axis turned off
M92/$[#20104]
G91 G20 G1 $[#20104]30.596 F1800.0
M26/$[#20104]
N1000
Re: Checking Parameter 800 in a Macro File (Answered)
Answering my own original question here. Parameter 800 can be used in a macro file as evidenced by the mfunc10.mac file that ships with V4.12
;M10 Clamp rotary
IF #4201 || #4202 THEN GOTO 1000
IF #50001                         ;Prevent parsing
IF #9800 == 0 THEN M94 /88        ;Disable cfg timeout timer if configuring axis
IF #9800 == 0 THEN M224 #100 "The 4th axis is not configured for clamping.\nEnter 1 to configure for clamping.\nEnter 2 to configure the 4th axis without clamping.\nEnter 0 to exit without configuring the 4th axis.\nPress Cycle Start to continue when done"
IF #9800 == 0 THEN G10 P800 R#100 ;Write to 4th axis config parm
IF #9800 == 1 THEN M94 /4         ;Request clamp
IF #9800 == 1 THEN G4 P1          ;Wait for clamp
N1000
That said, CNC_Smith's response was actually a better solution to my problem as parameter 800 can be set to signify that the rotary axis has been CONFIGURED, but it does not guarantee that it is currently enabled. Checking the axis label does do that.
