RotaryTableHome IS INP8 ;RTB 12/28 - DoorClosed IS INP8
RotaryTableClamped IS INP13 ;RTB 12/28 - SpinLowRange IS INP13
;spare RTB 12/28 SpinMedRange IS INP14
;spare RTB 12/28 SpinHighRange IS INP15
;spare IS INP16
Mist IS OUT4 ;RTB 12/26 - MistOrClamp IS OUT4 ;SPST Type Can be configured for Mist or Clamp
InverterResetOut IS OUT5 ;SPST Type
WorkLightOut IS OUT6 ;SPST Type
SpindleEnableOut IS OUT7 ;SPST Type
SpindleDirectionOut IS OUT8 ;SPDT Type
RotaryTableClamp IS OUT9 ;RTB 12/26 - ZBrakeRelease IS OUT9 ;SPDT Type
;RTB 12/26 split mist coolant (out4) from clamp (out9)
;;--Mist coolant on/off
;IF !ClampEnabled_M && (CoolMistKey || KbMistOnOff_M) THEN (CoolantMistPD)
;IF (ClampEnabled_M && M10) || (!ClampEnabled_M && (((Mist ^ (!CoolAutoModeLED && CoolantMistPD))
; || CoolAutoModeLED && M7)
; && !(SV_STOP ||
; CoolAutoModeLED && !M7 ||
; ErrorFlag_M ||
; DoToolCheck)))
; THEN (Mist), (CoolMistLED), (SelectCoolantMist)
;IF ClampEnabled_M THEN RST CoolMistLED, RST SelectCoolantMist
IF CoolMistKey || KbMistOnOff_M THEN (CoolantMistPD)
IF ((Mist ^ (!CoolAutoModeLED && CoolantMistPD))
&& !(SV_STOP ||
ErrorFlag_M ||
DoToolCheck)
; Rotary Table Clamp on/off
IF (ClampEnabled_M && M10) THEN (Clamp)
