[Video] Clint Branham Video, Acorn Surface Touch Off with Tool Touch off
Clint Branham Acorn User video shows how he is using a material surface height detector in conjunction with a tool height detector with his Acorn CNC controller. he says... This is my first CNC video. It is a video of an M6 macro for setting the Z0 to either the top of the part or the top of the spoil board and reference a fixed tool touch off and set subsequent tool changes to that height. It is soooo nice to have macros that just work. Unlike Mach3.
Macro download.
mfunc6.mac
(11.43 KiB) Downloaded 484 times
1. Setup your G28 Return #1 "Tool change position"
a) F1-Setup, F1-Part. F9-WCS Table, F1-Return
The fields under G28 are in machine position, press alt-d to toggle your display between machine position and wcs position
b) Jog the machine to the position you want to physically change the tool at. Enter the X, Y and Z machine position values displayed in dro. It is strongly suggested to leave Z at 0.
c)F10-Save
2. Setup your G30 Return #2 "Tool touch off device position" ** Not needed if you do not have a permanently mounted tool touch off device
a) F1-Setup-, F1-Part,F9-WCS Table, F1-Return
The fields under G30P2 are in machine position, press alt-d to toggle your display between machine position and wcs position
b) Jog the machine to the position directly over your tool touch off device. Enter the X, Y and Z machine position values displayed in dro. It is strongly suggested to leave Z at 0.
c)F10-Save
3. Setup the height of the movable tool touch off device in parameter 71
a) F1-Setup, F3-Config(pw=137), F3-Parms
b) Measure the height of the detector at it's location - enter that value in parm 71, press enter
