Mach 3 Fast Jogging
jholland
CNC Control System Serial Number: A900078
Re: Mach 3 Fast Jogging
Post by jholland »
Jackson,
It is my understanding that you are running CNC11. Is that correct?
If so, any issues you are having with jogging are not related to this post/topic. Please feel free to post in a separate thread if you are having trouble configuring jogging in CNC11.
If indeed you are running Mach, I have posted a solution withing this topic.
Alex
you are not alone. I get yellow led on screen but no fast jog motion. Slow jog is ok.
Looking forward to meaningful information.
jh
Centroid_Tech
Post by Centroid_Tech »
Don't have an answer to jog issue, hope to have an answer for you on Monday.
I checked with our software guys and in order to toggle between fast jog and slow jog you will need to create a brain to map the shift key to toggle modbus output 377.
pwborst
Post by pwborst »
i am very inexpreienced with brains and would like to know how to map a keyboard press to an output.
Thank you
diycncscott
Re: "Ref All" Mach 3 Fast Jogging
Post by diycncscott »
Hi Alex
Sorry I missed your email. I sent an email reply along with the username and password.
You can use "Reference All". In Mach select "Operator" -> "Edit button script" -> click on the "Ref All' button when flashing, remove the exisiting code and insert: (copy and paste only the text in bold)
code "M92 P1 Q2 R3"
Which says to move the X, Y & Z axes simultaneously to the positive limits and then home at the index pulse. You can modify the P1 Q2 R3 to suit the direction and axes you wish to home.
You may also want to consider splitting the homing into two commands instead:
Home the Z first to make sure it's clear:
code "m92 P3"
sleep 100
While IsMoving()
sleep 100
Wend
sleep 1000
Then home the X & Y:
code "m92 P1 Q2"
Then save and exit.
I'll look into the fast/slow jog this morning
diycncscott
Here is a Brain that will enable fast jogging when holding the shift key.
[The extension brn has been deactivated and can no longer be displayed.]
Please note that this Brain does not look at the shift key itself but rather the fast jog LED that Mach sets when it sees the shift key is pressed.
Copy this to your c:\mach3\brains directory and then enable the Brain in Mach by selecting "Operator"->"Brain Control"->"Reload All Brains"->
select fast_jog.brn then check the "Enabled" box ->"Reload All Brains"
Done.
NOTE: If you have the Ajax machine control pendant, do not install this Brain. Fast/Slow jog is handled already in the pendant Brains.
pwborst
Post by pwborst »
fast jog still doesn't work for me. in fact the fly-out software mpg on mach (i.e. the window that comes out when you push the "tab" key) has never worked for me. is there something i need to change. i can jog with the arrow keys and the pg up and pg down but not with the software buttons.
Thank you for all youre help
diycncscott
Hello,
I'll look into that. I honestly have never tried jogging with the screen buttons.
