M400 control not powering up
Posted: Thu Jul 17, 2025 2:58 pm
by ClydesMFG
I have an older M400 Centroid on a bridgeport style mill and I went to power it up after a couple weeks off and the computer wont power up the cabinet powers up but the controller doesn't I'm not even sure where to start trouble shooting and this post maybe in the wrong category.
Re: M400 control not powering up
Posted: Thu Jul 17, 2025 3:09 pm
by centroid467
Hello and welcome to the forums.
If the computer is not powering up, the first thing I would check is the power supply in the PC. If that is not working then replace it with an equivalent ATX power supply.
Posted: Thu Jul 17, 2025 3:53 pm
by ClydesMFG
I have power going to the power supply but its not powering up the computer im going to order a new power supply and we will see if that works
Posted: Thu Jul 17, 2025 4:02 pm
by cncsnw
There have been quite a few generations of M400 controls.
If yours was built between ca. 2003 and ca. 2015, so that it uses a micro-ATX motherboard and corresponding power supply, then the issue might just be that the motherboard battery is dead. See https://www.centroidcnc.com/dealersuppo ... ds/272.pdf
If yours was built between 1996 and ca. 2002, so that it uses a PC104 motherboard and either a MeanWell switching power supply or an AT-style power supply, then the issue could be the power supply, but is more likely to be a dead motherboard (bad news, with that generation of console).
If yours was built after ca. 2015, so that it has a NUC or BeeLink mini PC in the console, then it could again be the computer battery (although in that case you should have 12VDC - 19VDC coming from the power supply).
If you are not sure when your console was built, tell us the Centroid control serial number from the tag on the back or side of the console.
Posted: Thu Jul 17, 2025 10:09 pm
by ClydesMFG
I believe it was 2005-06 the SN# 20325
Posted: Thu Jul 17, 2025 10:11 pm
by ClydesMFG
after reading your PDF the power supply fan does not turn on at all
Posted: Fri Jul 18, 2025 12:08 pm
by cncsnw
If it does not turn on at all when you apply AC power, then the next step is to momentarily short the motherboard's power-button pins together.
If the power supply does not turn on at all when you apply AC power and momentarily short the power-button pins together, then the power supply is probably faulty.
Posted: Wed Jul 23, 2025 3:59 pm
by ClydesMFG
well new power supply installed machine boots up but now I've lost the monitor guess ill try and track 1 of those now or could it be something else? ok update its the screen or the little board for the screen but hooking up an old VGA monitor directly to the computer system and that works not fixed but at least I'm not down while ill have to wait for more parts to come in. It makes me wonder if its worth looking into a full pc upgrade for my machine. Any thoughts on that would be great.
