During the test of "Check CPU Preformance" it just stops without any warning.
My config is a new PC with:
- Windows 11 64 bit Pro
- 32 GB RAM
- Samsung SSD 990 Pro 2TB fixed hard disk
- AMD Ryzen 7 9800X3D 8-core CPU
I use this PC also for Insta360, Fusion and Bamu Studio.
pc tuner 1.3.1 R20110
- CNC Control System Serial Number: 0329225831
- Tech Support
Re: pc tuner 1.3.1 R20110
When you say it "stops" do you mean the application crashes or it won't move past that check?
Your CPU blows away our minimum requirements, so you're definitely good there.
