What vfd can I run with this motor
- CNC Control System Serial Number: 300003
I’m running this motor at 220v what vfd should I purchase to run correctly
Re: What vfd can I run with this motor
Voltage is important but more important is the HP rating of the motor. I can't see this in your photo. The correct VFD depends on your budget. You could buy a Chinese VFD on Amazon for $75 or you could buy a good one for $300. There is no right answer.
I should purchase on based on hp and voltage needs
300$ is good with me if it does the trick
This is a tolerably decent one, which will run on single-phase input:
https://www.automationdirect.com/adc/sh ... /gs21-21p0
