VICTOR NC5VS KNEE MILL, SERVO3IO, M400S SETUP <Answered>
NoahP678
CNC Control System Serial Number: 20035
Post by NoahP678 »
Hello, I am trying to figure out what the proper shut down procedure is for my mill that is currently running CNC7. I feel uneasy just cutting the power off without doing it programmatically on the control, as I don't want to damage it.
Thanks in advance.
Noah Pallares
REPORT.ZIP.zip
(30.09 KiB) Downloaded 6 times
eng199
Re: M400S RUNNING CNC7 PROPER SHUT DOWN
Post by eng199 »
Press Esc until the main screen is displayed. Turn off power.
DOS was not picky about shutdown. It did not have a multitude of files and processes open like newer operating systems.
NoahP678
Re: M400S RUNNING CNC7 PROPER SHUT DOWN <Answered>
Post by NoahP678 »
Thank you eng199, that's fantastic to know.
NoahP678
KNEE MILL, SERVO3IO, CNC7, M400S PROBE
Post by NoahP678 »
Hello everyone,
I need some assistance on figuring out how to add a probe to my knee mill (type, connection location, maybe programming). Thanks guys.
centroid467
Re: VICTOR NC5VS KNEE MILL, SERVO3IO, M400S SETUP <Answered>
Post by centroid467 »
Looking at the picture of your cabinet, I see what looks to be our standard probe header mounted to the top.
Type? Well, I'm going to recommend our own probes. If you don't have any particular requirements for a long stylus then a KP-1 should do the job. I would order KP-1 kit P/N: 15503 because it comes with the correct cable (P/N: 15431).
As far as programming goes, it looks like you will need the probing and digitizing cycles unlocked before you can do much with the probe.
NoahP678
Post by NoahP678 »
Thank you much. As far as the connector goes, If it is the same for the Height Tool, then the answer is yes. I am looking at ordering the probe you recommended. How do I go about unlocking the probing and digitizing cycles?
