Hello.
Question ...is there logging capabilities in cnc12?
so If I am running the machine something goes wrong and I could go back and look at the logs of what happened?
Tnx!
CNC12 logging info? <Answered>
- Plasma CNC Controller: Yes
Re: CNC12 logging info?
CNC12 logs the messages that appear in the message window in the upper right corner of the display. These logs are included in the report.zip and can be accessed within the CNC12 software.
On a Mill or Lathe installation, you'd press: F7 Utility Menu -> F9 Logs and from there choose F1 Errors to view the recorded error, warning, and informational messages in chronological order. You can also look at the quantity of each message in the F2 Stats menu.
Thank you!
