Hello,
I am running v4.82 and for some reasons on the vcp interface the minus z axis does not work when I click on it. The plus z axis does and i can use the MDi to goto an direction. However when using the mouse pointer on the minus z axis nothing happens.
I will appreciate if you can direct me how to troubleshoot.
Thank you
VCP -Z axis button doesnt not response
Re: VCP -Z axis button doesnt not response
The control probably thinks that you have a touch probe or tool setter which is tripped.
If you want more useful suggestions here, you will have to post a Report file.
- Tech Support
