I was wiring my laser as show on s15061 dwg and a soon I send the m 37 I bowl the laser that I have made repaire last month for 500$
What is not working !
LASER AND WIRING
LASER AND WIRING
- report_98F07B91EC1E-1115237702_2025-04-12_11-04-28.zip
- (1 MiB) Downloaded 46 times
Re: LASER AND WIRING
Would You help me , can you really wiring a Dpss laser on your board .
hi, please keep everything in one thread or reiterate your components being used, photo album etc.
otherwise we have to go hunt to figure out what you are working with, in other words please make it easier for us to help you by posting all the information about your build. and please explain clearly what your issue it. back up with a video so we can see the screen and what is happening or not happening.
License: ACORN ROUTER PRO
Version: CNC12 Acorn Router v5.26
if you have no probe trigger and no touch plate trigger assigned. then remove the detects!
HomeAll INP1
ProbeDetect INP2
DriveOk INP5
TouchPlateDetect INP7
EStopOk INP8
post a link to the photo album for this project so we can see what you are doing.
HomeAll INP1
ProbeDetect INP2
DriveOk INP5
EStopOk INP8
New question for you cnckeith , on tb 326 rev 6 ,2 pages it mention that I have to cut the connection to output #2 and mention to S15049 schematic .
Can you please explain , it's not clear
You only want the PWM output coming out of the DB25 connector, not from Output 2. Cutting the cable ensures that won't happen. Be careful when you cut the cable because the output 2 wire is actually the third wire in the ribbon. It should look like this when you are done:
-Scott
