Building C# example
Make your own CNC Control Apps
equack
Building C# example
Post by equack »
In order to build the C# example (CentroidAPI_CSharp_PowerFeed) I had to delete the CentroidAPI assembly and reinstall it. Once I did that I was able to build the project without errors.
Here's how:
1. solution explorer->dependencies->assemblies->CentroidAPI (right click on this and remove it, or just hit DEL).
2. solution->explorer->dependencies (right click and choose Add Project Reference).
3. The Reference Manager will open. Choose browse.
4. A file dialog box will open. Browse to the Centroid working directory (on my system it is C:\cncm).
5. Choose the file "CentroidAPI.dll" and click "Add".
6. Click OK in the Reference Manager.
7. Build your project with Build->Build Solution
Centroid_Jacob
Web Developer
Re: Building C# example
Post by Centroid_Jacob »
Thanks for this information, I will add these instructions to the API FAQ. It's likely caused by a version mismatch between my CNC12 dev install and your local dev install.
