Limit Switch for homing
Posted: Wed Oct 30, 2024 1:23 pm
by Reiko Röse
Hi,
I am retrofit a Knuth WF1 CNC Mill with a Acorn Controller. I have limit switches on all axis in plus and minus direction they a all wired in series.
Can I use them also for homing the machine or do i need a separate row switches?
Regards Reiko
Re: Limit Switch for homing
Posted: Wed Oct 30, 2024 1:33 pm
by suntravel
You need only one switch for each axis and set them up au Home Limit in the Wizard for the other direction use soft travel limits.
I think I know you from a German forum ?
Posted: Wed Oct 30, 2024 1:50 pm
by Reiko Röse
Hi Uwe,
yes you do. I know the method do you have described. Let me ask in a different way.
Can i use the same row of switches for both functions, homing and hardware limit?
Regards Reiko
Posted: Wed Oct 30, 2024 2:41 pm
Reiko Röse wrote: ↑Wed Oct 30, 2024 1:50 pm
Hi Uwe,
Can i use the same row of switches for both functions, homing and hardware limit? < yes
Regards Reiko
Posted: Wed Oct 30, 2024 2:44 pm
by suntravel
Yes Home Limit ist doing this, used for Home and Limit after homing is done.
If wired in series, use HomeLimitAll in the Wizard for this input.
Posted: Wed Oct 30, 2024 3:05 pm
by Reiko Röse
Thanks thats the answer i was looking for. Because i couldn't find the HomeLimitAll configuration in the Installation Manual.
