Limit Switch for homing
Reiko Röse
CNC Control System Serial Number: 54453808391C-0702248376
Post by Reiko Röse »
Hi,
I am retrofit a Knuth WF1 CNC Mill with a Acorn Controller. I have limit switches on all axis in plus and minus direction they a all wired in series.
Can I use them also for homing the machine or do i need a separate row switches?
Regards Reiko
Re: Limit Switch for homing
You need only one switch for each axis and set them up au Home Limit in the Wizard for the other direction use soft travel limits.
I think I know you from a German forum ?
Reiko Röse
Hi Uwe,
yes you do. I know the method do you have described. Let me ask in a different way.
Can i use the same row of switches for both functions, homing and hardware limit?
Regards Reiko
Reiko Röse wrote: Wed Oct 30, 2024 1:50 pm Hi Uwe,
Can i use the same row of switches for both functions, homing and hardware limit? < yes :D >
Regards Reiko
Yes Home Limit ist doing this, used for Home and Limit after homing is done.
If wired in series, use HomeLimitAll in the Wizard for this input.
Reiko Röse
Thanks thats the answer i was looking for. Because i couldn't find the HomeLimitAll configuration in the Installation Manual.
