What does the Y in DIY stand for? we give you the tools so you can do it yourself!
As a reminder Centroid CNC12 is easily customized by anyone. All the tools to Do it Yourself are freely available, such as our advanced macro programming, PLC programming, VCP programming and even high level APi all at no charge. You can change any message, word, function, button, color, image that you want or even create your own CNC app to work with or completely replace the CNC12 UI. Centroid provides complete working ready-to-run user interfaces for Mills, Lathes, Routers and Plasma machine tools, use these as is or modify to your liking. Any CNC12 installation can be modified to suit the machine tool application or the user's preference.
CNC12 v5.20 release notes.
https://www.centroidcnc.com/centroid_di ... _notes.pdf
Macro Programming
https://www.centroidcnc.com/centroid_di ... amming.pdf
VCP Programming
PLC Programming
Centroid APi instructions are included with every CNC12 install
c:\cncm\CentroidAPIDocumentation\ click on the documentation short cut in this folder.
and any questions asked here on the forum about any of the above will be answered.
ZZBOB
CNC Control System Serial Number: 20915A (1124081904)
Re: What does the Y in DIY stand for? we give you the tools so you can do it yourself!
Post by ZZBOB »
A BIG THANK YOU....to CNCKEITH....
BOB.....
VCP is the same link as Maro...
