CNC12 Mill, Lathe, Router, Plasma v5.22 is now available.
CNC12 v5.22 software is now available for use with Acorn, AcornSix, Hickory, Allin1DC, Oak and MPU11.
This is a free CNC software update! All previous license files file work with this new version of CNC12
software (in their respective categories: Acorn mill licenses work with Acorn mill, Oak lathe licenses work
with Oak lathe CNC12, etc.)
Huge list of CNC Features and additions see the release notes here.
https://www.centroidcnc.com/centroid_di ... _notes.pdf
Release notes updated 10-29-24
As a reminder Centroid CNC12 is easily customized by anyone. All the tools to Do it Yourself are freely available, such as our advanced macro programming, PLC programming, VCP programming and even high level APi all at no charge. You can change any message, word, function, button, color, image that you want or even create your own CNC app to work with or completely replace the CNC12 UI. Centroid provides complete curated ready-to-run user interface for Mills, Lathes, Routers and Plasma machine tools, use it as is or modify to your liking. Any CNC12 installation can be modified to suit the machine tool application or the user's preference.
Download here.
Refresh your browser to see the latest page.
Please follow the installation instructions.
Do not use “restore report” using a report from an earlier version.
Download here.
1 user liked this post
Re: CNC12 Mill, Lathe, Router, Plasma v5.20 is now available.
pensez vous un jour ajouter les fonction Fz et VC dans l'intercom et donc le nombre de dents dans le tableau outil ?
Do you think one day adding the Fz and VC functions in the intercom and therefore the number of teeth in the tool table ?
- CNC Control System Serial Number: 0035FF8D294B-0211225688
I just updated to cnc V5.20
everything is fine, but the tool library is not automatically copied. it seemed to me that this was the case since V4.08.
I copied it manually.
Thank you for all these developments.
My optimum L28 CNC Lathe with ACORN
viewtopic.php?t=7831&hilit=aurelien
https://www.youtube.com/watch?v=Rqzrz87 ... reparation
Hi there, thanks! Yeah the tool library has never been automatically copied.
It's up to the user to copy over the work coordinates tool library offset library. Any custom macros, Any custom vcp as usual.
We're working on a wizard interface that would allow you to pick and choose what you would like to copy over from a older version.
Glad you decided to update. Thanks for sharing your feedback.
Oh I thought that was the case, as that was what you were saying in the video where you showed how to transfer the tool library. You said that since V4.18 there was no longer any need to follow this video.
please send me a link to that, looks like i need to clean up some old videos? thanks.
here
Today I have a problem with cnc12 v5.20
Keyboard jogging does not work even after activating with alt+J and in MDI no matter what I write whether it is to move an axis or activate or deactivate the spindle, nothing works.
with the VCP or the MPG remote everything seems to work correctly
I am attaching a report
- report_0035FF8D294B-0211225688_2024-11-11_19-05-57.zip
- (1.03 MiB) Downloaded 14 times
a safety feature for keyboard jogging has been added to v5.20, covered in the release notes.
press CTRL to let CNC12 know that the PC keyboard arrows keys, pg up, pg dn and 1,3,7,9 are going to send the jog command.
see the keyboard legend that CNC12 displays as well.
Note: this is a PLC program change. (not a change to CNC12 itself) the PLC program is human readable and there is extensive documentation provided by Centroid on how to customize your PLC program.
ok thank you keith.
And the problem with MDI mode? why is this not happening?
I am looking into it now.
