New Build - 1325 CNC retrofitted with Acorn
ross979
CNC Control System Serial Number: C181804
Post by ross979 »
Just uncrated 1325 CNC from China. Came with an old and unsupported version of NC Studio. Saving myself the heartache and upgrading to Acorn now. Link below to photo dump spot.
They have the x and rotary wired together. There is a switch on the side of the cab to select one or the other. This, so far, is my biggest concern to get right in the retrofit. Anyone else have a NC to Acorn thread please drop the link!
https://drive.google.com/drive/folders/ ... sp=sharing
centroid467
Re: New Build - 1325 CNC retrofitted with Acorn
Post by centroid467 »
You should be able to set this up with hardware pairing on the Y axis and free up the fourth axis output on ACORN for the rotary. I would probably try automatic homing and squaring using relays to interrupt the step signals in the homing macro. Instructions for that begin on page 9 of this document: https://www.centroidcnc.com/centroid_di ... _guide.pdf
You should connect the drives to the DB25 on ACORN. Here's a schematic for those MA860H drives: https://www.centroidcnc.com/dealersuppo ... 976.r4.pdf
What controls the spindle? Does IMG_4155.jpeg show the VFD terminals? If so, it looks like it is not set up to use analog 0-10V signals for setting the speed.
ross979
Post by ross979 »
centroid467 wrote: Thu Aug 01, 2024 12:36 pm What controls the spindle? Does IMG_4155.jpeg show the VFD terminals? If so, it looks like it is not set up to use analog 0-10V signals for setting the speed.
Thanks for the reply. And yes that is the VFD terminals. What should I do different there?
Gary Campbell
Post by Gary Campbell »
I've retrofited a lot of Chinese machines over the years. A few of them have decent VFDs and stepper drives that I kept, but for the most part my rule was to: "replace everything with a wire attached to it"
Mattwo_support
Post by Mattwo_support »
ross979 wrote: Thu Aug 01, 2024 1:23 pm
Can you post the manual with wiring diagrams? What are those 5 terminals labeled as?
ross979
Post by ross979 »
Mattwo_support wrote: Thu Aug 01, 2024 2:03 pm
I have asked Forsun for the manual, I am unsure if I will get a reply.
Those are labeled: S1 - S3 - S4 - S5 - DCM
I added a couple more pics to try and show labels better on the VFD.
ross979
Post by ross979 »
Gary Campbell wrote: Thu Aug 01, 2024 1:35 pm I've retrofited a lot of Chinese machines over the years. A few of them have decent VFDs and stepper drives that I kept, but for the most part my rule was to: "replace everything with a wire attached to it"
It came loaded with a Leadshine clone driver. Would it work to buy the name brand, same model, driver and swap them in? Would that cause chaos with the motors?
Recommended VFD brands?
Gary Campbell
ross979 wrote: Thu Aug 01, 2024 10:21 pm It came loaded with a Leadshine clone driver. Would it work to buy the name brand, same model, driver and swap them in? Would that cause chaos with the motors?
I can't answer that for you. Many of the cloned (read as cheaper) drives that are OEM on Chinese machines have the same cases, but substantially reduced components on their internal circuit boards. This often results in reduced features, but almost always results in reduced ability to handle the ever present EMI. If you were going to change them out I would suggest going with closed loop steppers and matching motors.
I use Hitachi, Yaskawa, Automation Direct (Delta) VFDs as a first choice (depending on availability) and on budget builds Sunfar or its clones Simphoenix or Philcam. I avoid the cheaper HY as it is almost impossible now to detect some of their bad clones.
ross979
Post by ross979 »
Gary Campbell wrote: Fri Aug 02, 2024 10:42 am
Thank you!
ross979
Post by ross979 »
Here is the manual for the VFD, any help here is really appreciated y'all!
https://drive.google.com/drive/folders/ ... drive_link
