CHIPS
Jrlee
CNC Control System Serial Number: F045DA798AE4-1119181352
CHIPS
Post by Jrlee »
I am preparing to setup CHIPS on my router and I am thinking there must be a standard image I can use for the VCP button. Are the users generating their own or is there a standard SVG image available?
thank you
Jr
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Re: CHIPS
Post by Nigelo »
The CHIPS icon is automatically installed with the CHIPS app. You will also be guided with the exact position on the VCP where you want it placed
Suggest you follow Swissi's detailed Instructions on this Forum where all of this is covered
Hope this helps
Nigel
Jrlee
Re: CHIPS
Post by Jrlee »
Nigelo thank you for your response. So I repeated the start of the install of CHIPS a little while ago and when I got to the point of selecting the location for the new CHIPS button CNC12 went away as before. But this time I moved document away that remained on the display screen and found the VCP panel that I was to select the location for the new button. I should be able to finish tomorrow I hope.
Thank you again
Jr
