Parameter 300-302 not assigning drive to axis
610Garage
Post by 610Garage »
I'm setting up my acorn controller to run my plasma cutter. Do to wiring aesthetics, I have drive 1 connected to the z axis. I attempted to change the axis dive number through he wizard, but it dosn't give me that option. I tried to change parameter 300 and 302, but that has no effect as well. Am I missing a parameter?
Thanks.
Joey
Plasma/Laser Lead
Re: Parameter 300-302 not assigning drive to axis
Post by Joey »
Wow sorry I missed This Post.
For Acorn Plasma the Axis cannot be changed. The Axis are always 1 X/ 2 Y/ 3 Z.
Technically the axis could be changed but specifically for Plasma this will lead to other issues.
What was the reason for Z to be the 1st axis?
610Garage
Post by 610Garage »
Aesthetics. Don't judge. :lol: I originally had the left two drivers wired to drive 3 for Y axis(long axis). I did not feel like trying to rewire it while making it look nice. I was also trying to save drive 4 for a second Z for an additional plasma torch head. I ended up setting it up for auto squaring. So each driver got it's own output and I'll manually switch torch heads if I even utilize my larger plasma cutter.
Thanks for the response though.
please use the Centroid CNC configuration Wizard for cnc setup rather than hand editing parameters.
Much better chance of success using the Wizard for you first time. :D
and you can hardware pair the axis drives on the gantry and still get autosquaring for the gantry while freeing up the 4th axis for other duties
610Garage
Post by 610Garage »
cnckeith wrote: Thu Aug 01, 2024 2:37 pm please use the Centroid CNC configuration Wizard for cnc setup rather than hand editing parameters.
I have a cnc mill that uses oak board. Nice system, but I don't believe that has a wizard. I set everything up from the parameters screen. So it was my first instinct here. But I have been using the wizard for most things on the acorn now. It is a wee bit easier. 8-)
cnckeith wrote: Thu Aug 01, 2024 2:39 pm and you can hardware pair the axis drives on the gantry and still get autosquaring for the gantry while freeing up the 4th axis for other duties
Yea, I saw that. To implement that strategy, it would involve completely rewiring my drivers. That took me days to wire them in like that. I don't need a 4th axis that badly.  :D Thanks though.
ok i moved this thread out of the Acorn Plasma forum.
