Gecko 214 Wiring Diagram To Acorn
Re: Gecko 214 Wiring Diagram To Acorn
Followed the drawing. Only 4 wires. Bad motor? It works when wired to a g201.
I can only speak to the drive I tested. There is a second one, I will check it tomorrow.
Please consider this unresolvable.
6 pages and no posting of the resolution?
I just had time today to check the second GR214V. No issue. It behaves the same as the first one.
However, I noticed the microstep dipswitch settings on the UART+Standby marked unit are reversed from the non marked unit.
In any case both drives work fine with Acorn
Okay, thanks Marty. They were shipped back early this morning. Moot Point. The idea was to run two motors concurrently but oh well.
Not moot really.
Just pointing out that the GR214v drives do work well with Centroid Acorn.
I get it, but it is time to make a call when you have 400 hours and $800 thrown at a problem that never got resolved. I have one drive running fine right now and it has been for 5 months. The problem arose when a three had to work together. Testing a single drive on one setting for a few moments answers very little in the scheme of things. Hopefully, no else encounters this problem.
Many questions unanswered. Centroid testing only echoed what I already said I managed to accomplish.
Three axis were tested together
No tests under load were done
Why do Gecko 201 drives work and 214 with the revised wiring do not?
I have been running 2-201's and 1 - 214 since July but couldn't switch the 201's for 214's, why?
All suggestions and changes since July have been carried out and the problem still persisted.
I have attached a copy of this thread for the people at Geckodrive to review and see if they have any insight.
Are all the stepper motors the same make and model, all windings connected in the same manner?
