Gecko 214 Wiring Diagram To Acorn
tuffduck
Re: Gecko 214 Wiring Diagram To Acorn
Post by tuffduck »
Followed the drawing. Only 4 wires. Bad motor? It works when wired to a g201.
Plasma CNC Controller: Yes
tuffduck wrote: Thu Dec 02, 2021 12:25 am Why would 201s work and 214s not work. I have a revision 2 that works but 3 revision 3s that do not.
I can only speak to the drive I tested. There is a second one, I will check it tomorrow.
tuffduck
Post by tuffduck »
Please consider this unresolvable.
CNCMaryland
CNC Control System Serial Number: F045DA7CBF8b-103011290
Post by CNCMaryland »
tuffduck wrote: Fri Dec 03, 2021 10:40 am Please consider this closed.
6 pages and no posting of the resolution?
I just had time today to check the second GR214V. No issue. It behaves the same as the first one.
However, I noticed the microstep dipswitch settings on the UART+Standby marked unit are reversed from the non marked unit.
In any case both drives work fine with Acorn
tuffduck
Post by tuffduck »
Okay, thanks Marty. They were shipped back early this morning. Moot Point. The idea was to run two motors concurrently but oh well.
tuffduck wrote: Fri Dec 03, 2021 5:24 pm Okay, thanks Marty. They were shipped back early this morning. Moot Point.
Not moot really.
Just pointing out that the GR214v drives do work well with Centroid Acorn.
tuffduck
Post by tuffduck »
I get it, but it is time to make a call when you have 400 hours and $800 thrown at a problem that never got resolved. I have one drive running fine right now and it has been for 5 months. The problem arose when a three had to work together. Testing a single drive on one setting for a few moments answers very little in the scheme of things. Hopefully, no else encounters this problem.
tuffduck
Post by tuffduck »
Many questions unanswered. Centroid testing only echoed what I already said I managed to accomplish.
Three axis were tested together
No tests under load were done
Why do Gecko 201 drives work and 214 with the revised wiring do not?
I have been running 2-201's and 1 - 214 since July but couldn't switch the 201's for 214's, why?
All suggestions and changes since July have been carried out and the problem still persisted.
I have attached a copy of this thread for the people at Geckodrive to review and see if they have any insight.
Are all the stepper motors the same make and model, all windings connected in the same manner?
