No motor movement
Re: No motor movement
Motors are energized. Only time A axis shows is when not paired to 2. Dose it not show when paired? do not know why images are reversed and upside down
- report_F045DA7F0780-0102191493_2019-01-24_10-57-32.zip
- (198.95 KiB) Downloaded 108 times
If you are using two stepper motors on a gantry axis they need to be paired. When paired they are used to drive the same axis so it will not show it as the A axis.
Are all axis working looks like you trying to run gcode
Russ
Russ
Well a step closer have two motors paired.
Do you have a "Pro" license installed? Without it axes wont pair
What do you mean pro license?
There is a free copy of Mill / Lathe software. The Pro version (cost circa $130) allows 'more'. In this case it sounds like to use the slave facility you need the Pro version.
http://www.centroidcnc.com/centroid_diy ... oller.html
Scroll down on the page.
- Plasma CNC Controller: Yes
- Hickory CNC Controller: Yes
Search Hardware Axis Pairing
IF you use the SOFTWARE to pair the axis you need Pro
See image
Is there another wiring diagram we can try?
You are correct on pairing.
