No motor movement
Kutton
Re: No motor movement
Post by Kutton »
Motors are energized. Only time A axis shows is when not paired to 2. Dose it not show when paired? do not know why images are reversed and upside down
report_F045DA7F0780-0102191493_2019-01-24_10-57-32.zip
(198.95 KiB) Downloaded 107 times
cncman172
CNC Control System Serial Number: 985DAD429EE9-0926170118
Post by cncman172 »
If you are using two stepper motors on a gantry axis they need to be paired. When paired they are used to drive the same axis so it will not show it as the A axis.
Are all axis working looks like you trying to run gcode
Russ
Kutton
Post by Kutton »
Well a step closer have two motors paired.
Kutton
Post by Kutton »
Gary Campbell
Post by Gary Campbell »
Do you have a "Pro" license installed? Without it axes wont pair
CNC Depot Modular ATC kits
Kutton
Post by Kutton »
What do you mean pro license?
Chaz
Post by Chaz »
Kutton wrote: Fri Jan 25, 2019 1:16 am What do you mean pro license?
There is a free copy of Mill / Lathe software. The Pro version (cost circa $130) allows 'more'. In this case it sounds like to use the slave facility you need the Pro version.
http://www.centroidcnc.com/centroid_diy ... oller.html
Scroll down on the page.
Search Hardware Axis Pairing
IF you use the SOFTWARE to pair the axis you need Pro
Kutton
Post by Kutton »
See image
Kutton
Post by Kutton »
Is there another wiring diagram we can try?
You are correct on pairing.
