Re: E stop switch and Contactor
Posted: Wed Apr 19, 2023 10:51 am
Got it, thanks Shawn!ShawnM wrote: ↑Wed Apr 19, 2023 12:17 am Two NC contacts on your estop are what's used in diagram S15117. A single NC estop switch is what's used in diagram 14953. Yes, they both work and do different functions. The relays on the Acorn relay board are rated for 250 volts so yes, you can run 120v through it. The ratings for the relays are printed right on the top of the relay.
