Hardinge TFB
Re: Hardinge TFB
Milton,
That's actually the stock Hardinge control enclosure. I had to cut out the fan and grill openings.
Re: Hardinge TFB
Final updated schematic. Needed to invert the Z-axis handwheel encoder; added a Z-axis glass scale; added spindle motor fan; swapped the status light for a two color red/green indicator (green when ready to run/flashing red when in e-stop or faulted). With the addition of the z-scale, this fills up the OAK's available encoders with 2 servo feedbacks, 2 handwheels, 2 glass scales, and 1 spindle encoder. All of the encoder and servo cables are documented on the schematic.
- HLV-H10140T-CNC-Final.pdf
- (489.91 KiB) Downloaded 291 times
Re: Hardinge TFB
Tom, Hello. very impressive install. thanks for taking the time to post photos so other could see your work. K
Re: Hardinge TFB
looks nice, what ballscrews did you use?
Todd
Todd
Re: Hardinge TFB
They were from Hiwin made to my specs. 25mm diameter with 5mm pitch on Z and 16mm diameter with 2.5mm pitch on X.
- Hiwin Ballscrews Production Drawings.pdf
- (443.73 KiB) Downloaded 246 times
Re: Hardinge TFB
got an old chucker to convert. that had almost no use. thanks
Re: Hardinge TFB
Hiwin is great, and custom screws are not much more than standard screws elsewhere. Quality and specs are top notch and screws are made in Taiwan - not China.
Re: Hardinge TFB
tblough wrote: ↑Tue Jan 16, 2018 1:40 pm Final updated schematic. Needed to invert the Z-axis handwheel encoder; added a Z-axis glass scale; added spindle motor fan; swapped the status light for a two color red/green indicator (green when ready to run/flashing red when in e-stop or faulted). With the addition of the z-scale, this fills up the OAK's available encoders with 2 servo feedbacks, 2 handwheels, 2 glass scales, and 1 spindle encoder. All of the encoder and servo cables are documented on the schematic.
Mind sharing what program you use for creating your schematics?
Re: Hardinge TFB
I don't mind sharing, but I'm afraid it's not going to be of use for most people. The schematics were done with AutoCAD Electrical which is an extremely pricey piece of software. Fortunately, Autodesk is very education friendly and my work gives me access to the academic versions of Autodesk software.Wolfenstien wrote: ↑Sun Feb 17, 2019 8:57 am Mind sharing what program you use for creating your schematics?
If AE wasn't an option, I probably would have used KiCad.
Re: Hardinge TFB
Found a few more photos in the archives:
