SOLVED! Thanks to ScottW for helping figure this out. He said he thought the tool change routine had taken the focus off the CNC12 software, and clicking on the Blue area might return focus and free it up. That didn't do it, but an additional Cycle Start DID free it up!
I'm still not sure why the Z commands on the virtual keyboard did work, when the X & Y moves didn't? Anyway, I don't need to know all the behind the scenes as long as it works.
Just upgraded to v5.20. Went pretty smoothly and was glad to be able to have my Touch Off - Z plate and Probe set up and available.
My issue is with the "ALT J" keyboard control.
It works fine until I do an automatic tool change, then it will execute 1 move command in X or Y (doesn't matter how far it moves) Then X and Y are nonresponsive, but Z still works. Both my wired and wireless keyboards have the same symptoms. The touch screen or mouse still has control of all axis.
I have a tool changer by Rapidchange ATC which was working fine on v5.10.
I'm attaching a Centroid Report and also the Rapidchange mfunc6 file.
I have a converted Shopbot PRS, with original Gecko 202 drivers and Oriental stepper motors.
Hoping you can help, Thanks
David
cnckeith wrote: ↑Tue Oct 22, 2024 7:40 pm
CNC12 Mill, Lathe, Router, Plasma v5.20 is now available.
CNC12 v5.20 software is now available for use with Acorn, AcornSix, Hickory, Allin1DC, Oak and MPU11.
This is a free CNC software update! All previous license files file work with this new version of CNC12
software (in their respective categories: Acorn mill licenses work with Acorn mill, Oak lathe licenses work
with Oak lathe CNC12, etc.)
Huge list of CNC Features and additions see the release notes here.
https://www.centroidcnc.com/centroid_di ... _notes.pdf
Release notes updated 10-29-24
As a reminder Centroid CNC12 is easily customized by anyone. All the tools to Do it Yourself are freely available, such as our advanced macro programming, PLC programming, VCP programming and even high level APi all at no charge. You can change any message, word, function, button, color, image that you want or even create your own CNC app to work with or completely replace the CNC12 UI. Centroid provides complete curated ready-to-run user interface for Mills, Lathes, Routers and Plasma machine tools, use it as is or modify to your liking. Any CNC12 installation can be modified to suit the machine tool application or the user's preference.
Download here.
Refresh your browser to see the latest page.
Please follow the installation instructions.
Do not use “restore report” using a report from an earlier version.
