Chaining GCode File
Gerral
CNC Control System Serial Number: B4107B77A373-0905248481
Chaining GCode File
Post by Gerral »
At the completion of a job I'd like it to load the no_job_loaded.cnc file automatically.
I've not found any documentation to accomplish this in the GCode file itself. Is this actually possible?
Thanks in advance.
Chaz
Re: Chaining GCode File
Post by Chaz »
Oddly some of Uwe's vids popped up on my feed.
at 27 secs you can see G65 filename. Would that not work?
From the "Configuration" chapter of the Centroid operator's manual:
15.4.206 Parameter 401 – Forget Last Job Loaded
Setting this parameter to a value of 1.0 will cause the last job loaded to be forgotten and replaced with the name
“no_job_loaded.cnc” when the CNC software is started.
