My router has worked fine for about two years now. In the last week though, it has stopped motion without an alarm three or four times.
It has happened 10 minutes into a program and as much as 2 hours into a run.
Could a clue be found in the report Zip? I cannot make out much.
Thanks for any help.
Motion stops - no error
- report_98F07B92141A-0329237035_2024-11-06_16-47-53.zip
- (964.87 KiB) Downloaded 5 times
Re: Motion stops - no error
Do you have closed loop steppers or servos?
CNC Depot Modular ATC kits
Nothing abnormal in the message log for the past 3 weeks. My guess is that you are encountering a drive error, but don't have the drive alarm signal connected to an Acorn input. Next time it happens, check the drive states inside the cabinet.
