incorrect cutting in a pocket <cutter comp in control vs cutter comp in cad/cam>
midy
Post by midy »
I'm trying to cut the pocket in the g code attached, and although the fusion simulation is correct, when out on the machine it is cutting approx 1,5mm too small all the way around. As usual I will be missing something obvious but hope someone can tell what i've done wrong. Cheers
k tech triangle centroid PP.nc
(14.54 KiB) Downloaded 4 times
mill tools.txt
(15.96 KiB) Downloaded 3 times
report_98F07B923769-0307236872_2024-10-03_15-49-58.zip
(952.68 KiB) Downloaded 2 times
Re: incorrect cutting in a pocket
Mill diameter in fusion is the same as you use on your mill?
midy
Post by midy »
yes it is
No Stock to leave in fusion?
midy
Post by midy »
no checked that also
Than you must have a problem in your machine's setup.
fusion and CNC12 is working perfect together.
midy
Post by midy »
well ive recently converted this machine from mach 3 and have cut hundreds of those pockets before, so yes i agree but just can't figure out what it is. Also I have another mill which has cut these pockets before with centroid and its now doing the same thing?? I can get around by telling the software it's a 4.5mm cutter instead of a 6mm but its not ideal
Post fusion f3d file pls,
midy
Post by midy »
https://a360.co/4dBtzAN
I think that should work
Thank you
There are no diameter compensation commands in the .nc file, so this is completely a fusion/operator issue. Did you leave stock for a finish pass and then not cut it?
