AutoZero Touch Plate Sienci Labs
ozarkwoodworker
Post by ozarkwoodworker »
I was wondering if anyone has seen this AutoZero Touch Plate from Sienci Labs.
Looks like a really nice setup, and shouldn't take much work to make it compatible with Centroid. I was thinking about getting one of these. The price seems quite reasonable. What do you guys think?
https://sienci.com/product/autozero/
https://www.youtube.com/watch?v=I1EhAPNXdzQ&t=74s
Ray
Gary Campbell
Re: AutoZero Touch Plate Sienci Labs
Post by Gary Campbell »
Other than my resistance to using conductive Z setters, that one should work, and there may be some features in an upcoming version that will make it easy to setup.
CNC Depot Modular ATC kits
I'm with Gary, there's no way I'm driving my $90 carbide tipped V bit into a solid metal surface......at any feed rate. :shock:
But if you are brave enough, this should work for you. :D
swissi
Post by swissi »
ozarkwoodworker wrote: Mon Jun 10, 2024 3:15 pm IMG_3693-1-scaled-e1677529189888.jpg
Ray
I would recommend the AvidCNC Touch Plate which has a spring loaded touch plate. This plate is fully supported in CHIPS.
-swissi
ozarkwoodworker
Thank you for the information. I was wondering what the new features are that may be coming that would help with this before I try to code something.
I also found this useful link from them that has resources where they have made this work with other CNC software.
https://resources.sienci.com/view/lmk2- ... er-senders
