Lathe setup, so only X and Z axis. No limit switches, I'll set soft limits since I have closed loop steppers.
Is there a reason I should wire the home switches in series to one input, rather than to separate inputs? I have the input since I'm not using limit switches.
Wiring up home switches
Re: Wiring up home switches
nope, you can do either, users that want to save on input use HomeAll other that don't using the individual home input definitions
cool. thanks.
