WMPG-6 jogs in reverse direction <parameter set incorrectly>
NeilS
Post by NeilS »
Hi,
Finally made some progress on my upgrade. I got all the axis motors up and working and configured for the right directions.
However using the jog buttons on the MPG-6 sends the axis in the opposite direction to the ones on the VCP. i.e. correct on VCP but inverted on MPG. I can't find any information on configuring the MPG on the web.
Neil
NeilS
Re: WMPG-6 jogs in reverse direction
Post by NeilS »
I will get a report to upload, but this is on an Allin1DC board with the latest version of CNC12 running.
Initially I thought it might be related to having to reverse the motor direction on X and Z as I had not got the Y motor back in. Now I have it is the same on the Y with the motor in the normal direction. On VCP the jog + moves the axis in the positive direction but on the WMPG the jog + button moves the axis in the negative direction.
You might have a look at parameter 1.
More likely Parameter 411.
NeilS
Re: WMPG-6 jogs in reverse direction - resolved
Post by NeilS »
many thanks,
It was Parameter 411 set incorrectly
