"Z compensation" on 4x8 foot CNC router
Re: "Z compensation" on 4x8 foot CNC router
upgrade from Pro is $225 (pro price - ultimate price)
cncsnw wrote: Wed Mar 13, 2024 12:14 pm I do not have time to review the volumetric compensation manual for you in detail right now. With luck, cnckeith or someone else who has worked with it can comment. But...
I do not think that volumetric compensation, as currently proposed, will do what you want. If I understand it correctly, it would add one Z correction amount for every X interval (in cnc-x.tab), and one Z correction amount for every Y interval (in cnc-y.tab).
If you want to map out a randomly undulating table surface, you don't just need X + Y compensation amounts; you need X * Y compensation amounts.
In other words, considering a 10" x 10" square of table surface, sampled at 1/2" intervals, the current implementation would give you 21 corrections based on X position, and 21 corrections based on Y position. You want 441 correction amounts based on an XY grid. The current implementation would work for a table surface that was perfectly flat, but not level in either direction; but it would not work for a table surface that is compound curved.
VC is 3D VC my demo was 2D to keep it simple and quick.
As an example, what would the compensation files look like for a router-like machine with a 10" x 10" work envelope, with a bowl-like depression in the table?
In this example, more Z- compensation is needed at X5Y5; less Z- compensation at X0Y5, X10Y5, X5Y0 and X5Y10; and no Z- compensation at X0Y0, X10Y0, X0Y10 and X10Y10.
cncsnw wrote: Wed Mar 13, 2024 6:16 pm As an example, what would the compensation files look like for a router-like machine with a 10" x 10" work envelope, with a bowl-like depression in the table?
ah! you are right, the full 3d comp has not been committed! still being tested internally, hope to publish soon.
