How to wire Huanyang VFD to Acorn to control spindle speed?
Re: How to wire Huanyang VFD to Acorn to control spindle speed?
mikeintx wrote: Tue Feb 27, 2024 10:26 pm Thanks for the tip on the VFD cable. I bought a premade16gauge double shielded cable from eDealers Direct Automation on EBay. This one: https://www.ebay.com/itm/144247023611?i ... SwOuRhaFOa
Bought a 25-foot version and will cut it to length. I can solder, but I can't solder 16ga wire into tiny terminal cups. Not like this guy can, anyway. Money well-spent IMO.
A 10 foot cable for $153 ?????? :shock: Seriously ??????
I also use Southwire VFD cable and it's awesome stuff. It's around $5 a foot plus or minus a few cents for either the 16/4 or the 14/4. Damn good cable.
mikeintx
CNC Control System Serial Number: 6679
Post by mikeintx »
ShawnM wrote: Tue Feb 27, 2024 10:48 pm
I agree, it is expensive. But, the VFD cable is a key part of the system and it's got to be right. I figured with what I was spending in total, having to literally buy everything else except the tools to put everything together, it was a small expense, comparatively speaking and money well spent for some peace of mind that it's done correctly.
mikeintx
Post by mikeintx »
I was able to successfully perform the spindle bench test. Ran into a small hiccup where the test program kept erroring that the voltage I was seeing was too low. Told me to check that max spindle speed was not above 3000 rpm.
Turns out the latest CNC12 available, v5.08, installs with a default spindle speed of 18000 rpm. Also, in the Wizard, in the Spindle section, I had to manually turn on PWM control. It doesn't mention any of this in the latest edition of the manual in the spindle bench test section on page 30. After I fixed those two things, the test went flawlessly.
mikeintx
Post by mikeintx »
cnckeith wrote: Tue Feb 27, 2024 9:55 pm
mikeintx wrote: Tue Feb 27, 2024 7:53 pm CNCKeith: The link to your "wire like this" doesn't work. Is there anything different or additional to what Marty does in the video? Thank you.
fixed https://www.centroidcnc.com/dealersuppo ... 984.r3.pdf
Just making sure I'm reading this correctly. There is a jumper between the P and PR terminals on the VFD, correct? Thanks.
mikeintx
Post by mikeintx »
Quick question: For the Spin Forward/Spin Reverse/VFD Reset/VFD Common connections between the VFD and relay board, is it OK to use 22-gauge wire, or I should I step up to 18ga?
I have a 500-foot roll of 22/4 shielded wire that I'd like to use if I can. I have no idea what kind of current/voltage are on those connections, so I'm asking before I melt something. Thanks!
22 is fine for those low amp signal wires
mikeintx
Post by mikeintx »
Thanks, cnckeith.
mikeintx
Post by mikeintx »
Can anyone confirm whether or not there must be a jumper between P and Pr (labeled P+ and PR on my VFD) as shown in the attached diagram? The VFD manual states those connections are for a braking resistor which I will not be using. Thanks.
I would assume not but it would be super helpful if you'd post a link to your VFD manual so we can give you the best answer possible. Not all Huanyang VFD's are created equal as there are many knockoffs out there.
IPGregory
CNC Control System Serial Number: 20D7787C45AB-0819226470 - 98F07B6F97F8-0623237343
Post by IPGregory »
mikeintx wrote: Wed Feb 28, 2024 7:25 pm Can anyone confirm whether or not there must be a jumper between P and Pr (labeled P+ and PR on my VFD) as shown in the attached diagram?
I don't have a jumper on mine. I read somewhere (may be wrong) that unless you order it from the factory with a resister, that circuitry is not installed.
If you don't have it, here is the manual.
Huanyang VFD Manual.pdf
(12.12 MiB) Downloaded 7 times
Thx
Ian
QueenAnt Pro V2 - CNC Router - https://photos.app.goo.gl/kg7CSvJsrAvAgRs26
MPNC - CNC Router - https://photos.app.goo.gl/ees2SER6C2Aw8AJ89.
