A (4th axis) homing
riggsp
CNC Control System Serial Number: 5050
Re: A (4th axis) homing
Post by riggsp »
Thanks for the help guys...I got the 4th axis in the mail yesterday and set it up today...changing the 4th axis .hom file to just home out did the trick.
Ashsrdtuning
Post by Ashsrdtuning »
Muzzer wrote: Wed Jul 12, 2023 9:31 am For when I use my 4th axis, I have disabled the 4th axis homing in the .HOM file, otherwise it will sit spinning forever. As Keith says, you can set home manually.
whats the easy way to do this ?
Ashsrdtuning wrote: Mon Nov 13, 2023 1:56 pm
edit the cncm.hom
add in
M26/W or what ever the rotary axis label is.
review the m code section of the operator manual (page 275) so you understand what the m code used in typical home programs do.
