Hello.
Can any one help me
I have a bridgeport style mill with and acorn set up on it.
When a m6 macro is ran to change a tool in a program it moves to the g28 x and y positions for me to change the tool
I know i can change these from the wcs table -> return table
But because of my vices and job set ups the spot I need to move the table to to change the tool can be difrent on every program
I would like to get up a button using aux 5 on the VCP so that I can move to the best place to change the tool then push this buttion and it will change only the x and y of the g28 to the current machine position.
Can any one tell me if this is posible?
if not can I do a work around? is there any machien positions that I can set in a macro?
Thank you
G28 XY Location Change via VCP
Re: G28 XY Location Change via VCP
How about just modifying your M6 macro to allow you to move as needed and then continue?
Scott
ok I think that If i could save the current machine Coordinates x and y to a user varable #100 & #101 for example
I could then recall this user verable and use G53 X#100 Y#101 then put this code in to my m6 macro in place of the G28
this should work
only problem i dont know how to save the current machine Coordinates to a user variable
any one know how to do this?
this should work
i think i found it 5021-5028 Machine Position (X=5021, Y=5022, etc.) Floating point value
- CNC Control System Serial Number: E06234795241-0928215226
This is awesome news for myself I have a knee mill also. I've been trying to figure this out myself. I'm not a very good at C++ programming I was trying to make this a post processor choice never figured it out.kcarpenter1986 wrote: ↑Tue Nov 07, 2023 5:04 am i think i found it 5021-5028 Machine Position (X=5021, Y=5022, etc.) Floating point value
If you don't mind could you point me in the right direction would be greatly appreciated.
