CNC12 v5.06 has been released.
Re: CNC12 v5.06 has been released.
I found a bug in 5.06 Arcor6 lathe.
RTG displays only the x-axis
On first start a lot of lines with Z position...
- report_0008DC111213-0511220026_2023-09-23_13-00-03.zip
- (1.02 MiB) Downloaded 52 times
Main Screen Lathe is also missing Machine Coord. and G-code.
Mill Acorn is correct.
Acorn Router does not reconniz my pro *.dat licence .
What to do
license-E415F6F138CC-1119204064-C146XXX -acorn-pro-router
What to do
post a fresh report.zip and the license file.
whoa! we are on it. thanks for reporting.
fixed in the latest beta release here.
https://centroidcncforum.com/viewtopic.php?f=67&t=9248
also release candidate for the Centroid CNC PC Tuner dropped today as well.
https://centroidcncforum.com/viewtopic.php?f=67&t=9157
CNC12 installation instructions have been updated to include all Centroid Hardware that is capable of running CNC12 and a introduction/discussion section has been added.
(Acorn users will be glad to have the Wizard if they read the Oak/Allin1DC/MPU11 sections)
https://www.centroidcnc.com/centroid_di ... ctions.pdf
- CNC Control System Serial Number: 74E182A80DDE-0312191753
After installing 5.06 (wpmp-4) on all axis x,y,z has only only one jog speed x1.
x10 , x100 fail to function.
- report_0C1C57043D5E-0423203177_2023-10-18_20-41-41.zip
- (877.81 KiB) Downloaded 57 times
A job worth doing “right", is!
I am sure the probe is tripped, check the input settings.
I get a fatal crash when I exit the Math Help screen:
1. Open either of the canned cycles. 2. Click on Math Help 3. Once in Math Help, click escape key on keyboard, or click the Esc icon on the screen.
A full software crash every time.
CNC12 Lathe v5.06 on ACORNSIX Lathe Pro
Report file attached.
Kind regards
Johannes
Steps I use to reproduce:1. Open either of the canned cycles. 2. Click on Math Help 3. Once in Math Help, click escape key on keyboard, or click the Esc icon on the screen.
Kind regards
Johannes
- report_0008DC111213-0116230086_2023-10-22_07-16-43.zip
- (793.36 KiB) Downloaded 61 times
