Two Machines, Two Wireless MPG's
greglwood
Post by greglwood »
Now that I am almost done with my Mill conversion and getting to know the centroid acorn a little better I am thinking ahead to converting my CNC Router to Acorn. This got me thinking about having two Wireless MPG's in the same room. I could not find anything in the manual about setting up an address or something that would distinguish these from each other.
Is it possible to have two Wireless MPG's attached to different machines in the same room?
Pics, Manuals. Specs, Datasheets for build - https://drive.google.com/drive/folders/ ... share_link
CNC12 Mill Pro
All in one CNCPC
Ether1616 Expansion Kit
Centroid Wireless MPG
2 Relay 8 Boards
Stepperonline 3Nm Closed Loop - CT57T Driver
Stepperonline 12Nm Closed Loop - CT86T Driver
Omron Encoder
DIG3D.LP.M Touch Probe
DIG3D.Fix Touch Off
Signal Isolator
Upnorth
Re: Two Machines, Two Wireless MPG's
Post by Upnorth »
I have read about people having two MPG equipped machines in the same shop. It should not be a problem. In this day and age the MPG's should set themselves up.
slodat
Post by slodat »
I have three Acorn powered machines in the same area of my shop. They are have the wireless MPG. Works great. No issues.
No problem to have multiple WMPGs.
greglwood
Post by greglwood »
slodat wrote: Sat May 13, 2023 9:15 pm I have three Acorn powered machines in the same area of my shop. They are have the wireless MPG. Works great. No issues.
Did you have to do anything to pair them or do they come uniquely paired?
CNC12 Mill Pro
All in one CNCPC
2 Relay 8 Boards
Omron Encoder
DIG3D.Fix Touch Off
Signal Isolator
slodat
Post by slodat »
I believe the way it work is the antenna/receiver and MPG are a pair from Centroid. I didn’t do anything. Worked out of the box.
Jep, they are delivered ready paired, only plug and play :D
Upnorth
Post by Upnorth »
Setup is very easy. All you have to do is plug the usb receiver into your computer. Then turn on the MPG in the acorn wizard and you are ready to go.
