Centroid Mill Turn PP for fusion 360 (WIP)
I wanted to have a Post Processor for fusion360 that puts out direct running g-code for my 4-axis lathe.
It is in the ZIP with the fusion file of this part here. If you want to crash your lathe, feel free to test it out, since I not really have a clue what I am doing :lol:
It is a modified PP from a Haas30SSY ( and some code borrowed from Centroid lathe PP ), so I left in the code for SubSpindle and B-Axis, maybe I need this the next time...
You also can choose G64 smoothing for milling, but right now it is not implemented in lathe software ( I hope it will be soon ;) )
Turret 1 is for front mount tools ( X positive )
Turret 2 is for rear mount tools ( X negative )
So far I have tested, CNC12 runs the g-code without errors, but I am working on it to make it more efficient.
Vectors for polyform milling with C-Axis are much longer now, for better running and shorter files.
CentroidMillTurn.zip
(267.16 KiB) Downloaded 112 times
1111.cnc
(65.96 KiB) Downloaded 118 times
Stephan
Re: Centroid Mill Turn PP for fusion 360 (WIP)
Post by Stephan »
Here is the first test from the PP not from Uwe
Thank you Uwe for the many tips
Unfortunately, I only have wood for testing. Aluminum is currently too expensive for me
Stephan
Post by Stephan »
So the PP is from Uwe is clear
Cool, that was fast :)
Stephan wrote: Wed Nov 23, 2022 2:22 pm So the PP is from Uwe is clear
New Version with Y-axis deselected by default and some useless posted lines corrected.
(32.75 KiB) Downloaded 101 times
New Version, tested for 2 live tools axial, radial and front/rear approach and turning.
Works for gang tooling also, makes long vectors, short files.
Nxxxx blocks are only written for tool changes to use easy search/run on Acorn.
File size for this part with engraving now is unter 4000 lines (started with 32000 lines only for the star)
Seems to run with any tool configuration on my lathe as posted from fusion without hand coding.
Stephan
Post by Stephan »
Der PP geht echt gut.
Ich danke dir für das zeigen. Die restlichen Ratter Macken hab Ich auch.
Kein Plan wie man das wegbekommt.
Mit Linear Führungen war es damals an meiner alten Kiste noch bissel besser.
Es ist wirklich frustrierend:
Ich glaube viele die kapieren es nicht oder die sind noch nicht soweit.
Dir schönen Sonntag
Stephan
Post by Stephan »
Habe gestern den PP das erste mal mit drehen und fräsen zusammen probiert.Fräsen läuft tatellos beim drehen gibt er leider den F0 aus.
Sorry hab es erst so spät bemerkt weil ich drehen immer mit Zyklen mache.
Kannst dir den PP bitte nochmal anschauen?
Hat aber Zeit
Danke Gruss Stephan
Current Version...
O02222
(post version: 44007)
(post modified: 2022-10-25 08:31:11)
(T101 NR=0.8 - ZMIN=-48.3 - general turning)
G21
G50 S2000
G28
(Face1)
N100 T101
M50
G99
G97
S1061 M3
G54
M8
G50 S2000
G96
S200 M3
G0 X60. Y40. Z5.
Z0.914
X40.
G1 X32.828 F0.2
X30. Z-0.5
X-1.6
X1.228 Z0.914
G0 X40.
Z0.414
G1 X32.828 F0.2
X30. Z-1.
X-1.6
X1.228 Z0.414
G0 X40.
Z-0.086
G1 X32.828 F0.2
X30. Z-1.5
X-1.6
X1.228 Z-0.086
G0 X40.
Z-0.586
G1 X32.828 F0.2
X30. Z-2.
X-1.6
X1.228 Z-0.586
G0 X40.
Z-1.086
G1 X32.828 F0.2
X30. Z-2.5
X-1.6
X1.228 Z-1.086
G0 X60.
Z5.
G97
S1061 M3
(Profile Roughing1)
G99
M7
G50 S2000
G96
S200 M3
G0 X50. Y40. Z5.
Z-1.9
X27.6
G1 Z-19.8 F0.2
G0 G3 X28.2 Z-21.3 I-3.6 K-1.5
G1 Z-48.3
X30.
X32. Z-47.3
G0 Z-1.9
X25.2
G1 Z-18.226 F0.2
G3 X27.6 Z-19.8 I-2.4 K-3.074
G1 X29.6 Z-18.8
G0 Z-1.9
X22.8
G1 Z-17.589 F0.2
G3 X25.2 Z-18.226 I-1.2 K-3.711
G1 X27.2 Z-17.226
G0 Z-1.9
X20.4
G1 Z-17.4 F0.2
G3 X22.8 Z-17.589 I0. K-3.9
G1 X24.8 Z-16.589
G0 Z-1.9
X18.
G1 Z-17.4 F0.2
X20.4
X22.4 Z-16.4
G0 Z-1.9
X15.6
G1 Z-17.4 F0.2
X18.
X20. Z-16.4
G0 Z-1.9
X13.2
G1 Z-3.692 F0.2
G3 X15.2 Z-6.3 I-2.9 K-2.608
G1 Z-17.4
X15.6
X17.6 Z-16.4
G0 Z-1.9
X11.283
G1 Z-2.917 F0.2
G3 X13.2 Z-3.692 I-1.941 K-3.383
G1 X15.2 Z-2.692
G0 Z-1.9
X9.365
G1 Z-2.526 F0.2
G3 X11.283 Z-2.917 I-0.983 K-3.774
G1 X13.283 Z-1.917
G0 X50.
Z5.
G97
S1273 M3
M9
M5
M87
G28
M30
Runs on my lathe as posted from fusion...
CentroidMillTurnV01.zip
(32.88 KiB) Downloaded 118 times
Stephan
Post by Stephan »
Thank you this PP is perfect
you told me that I can configure G28
i.e. the position where my X or Z axis goes when I type g28 in centroid
How does it work?
I made a big dent in my HF spindle
forgot to take them out
I thank you for your help
as always
Greetings Stephan
