New Rebuild on Sherline Chucker Lathe & New build on 5400 mill
Re: New Rebuild on Sherline Chucker Lathe & New build on 5400 mill
I know its not difficult and I have mill experience, this is killing me. I am reading the manual.
I just set offsets for 3 tools again. Started by 0 out all offsets and measuring manually.with 1,2,3 block. When done to check Z heights I then swap tools hit my M58 (GO TO Z0) DRO reads 0 but 2 of the 3 tools are off yet again. I have done this many many times over the last few days as i start learning set up with the manual, watching the video, etc. I am really frustrated! Same inconsistent Z0s after setting offsets. Also tried with tool touch same results as before. I dont get it!
Is there a config setting that is throwing me off?
Hers a current report.
- report_6433DB044D1E-0623214856_2022-06-27_21-33-31.zip
- (990.07 KiB) Downloaded 19 times
Is the DRO showing Tool T2 H2 when you move to Z0 with tool#2 ?
If not, call the tool#2 in MDI:
G43T02D02H02
G43T02D02H02
No, you can't assume that. You have to know how you set up YOUR tooling. You can have multiple offsets for the same tool. On mills this is often used to rough and finish with the same tool. On lathes, multiple offsets are often used with gang tooling. I have a small gang block that is tool 5. The four tools in the block have offsets of 51, 52, 53, and 54.
- Plasma CNC Controller: Yes
Bill make another video showing us exactly what you are doing
Do remember, once you set your tool offsets, you need to take anyone of those tool and set your part zero, remembering to tell the control WHICH tool you used to set the part zero.
You did fine tune your DRO correct? That is your Z axis movement is accurate and repeatable.
I suspect Uwe's comment above is what you need to look into. Unless you use the G43T3H3 type command to enable the tool length offset (for tool 3 in this case), the machine won't know and remember that tool 3 is the active tool and also apply its tool length offset.
If you are using Swissi's tool probing app, much of this is taken care of when measuring offsets. But even so, you will need to use G43 each time you change the tool and apply the correct offset. I assume you are sticking with G54 until you have sussed this out.
OMG really, so are you saying this is how you call up a tool? All that? LOL That must be what I'm NOT doing, because when I change tools Ive just been typing T1 T2 T3 etc. The DRO shows the tool I enter in MDI but the offset shows H.. NO offset.
So every time you call up a tool you have to type all that into the MDI? Geeze. Gcode machines not that easy! I guess what you dont know you dont know.
I figured you call up T2 T3 etc and the offset is associated with that tool, guess not. Something I have been questioning, now I know.
I have not come across this in the manual yet. I assume it would be in the running a job section?
OK, did not know this. I think I plan on using Swissi's probe app, waiting on probes to arrive. Down side for me I need to use probes for both machines and he does not offer it for lathe so am I better off just using CNC12 probing or use both? Not sure yet.Muzzer wrote: ↑Tue Jun 28, 2022 12:27 pm I suspect Uwe's comment above is what you need to look into. Unless you use the G43T3H3 type command to enable the tool length offset (for tool 3 in this case), the machine won't know and remember that tool 3 is the active tool and also apply its tool length offset.
Yes for now G54 only have no need for multiple part offsets yet.
Let me try changing tools using the proper command string and see where I end up, see my comments to Uwe I have not been doing that. Have not seen that in the manual yet, How to change tools properly. I was just entering T2 T3 etc.martyscncgarage wrote: ↑Tue Jun 28, 2022 8:54 am Bill make another video showing us exactly what you are doing
Fine tune DRO, not sure? BUT over the weekend I adjusted the mechanical backlash and dialed in the turns ratio and backlash in the control on the mill using your Emco 5 video on this. I got it about as close as I can get it within a thousand or so on X&Y not sure yet on Z still evaluating Z and trying to see if there is a better adjustment for mechanical backlash. BUT I am really close, I just need to check with Karl at Sherline and ask him what I can expect with my set up and the type of backlash adjuster I have on this machine. Now IF I am off still a bit it's not the discrepancy Im seeing when checking Z0 on a given tool as Im only a thou or so off on Z if that.
SO that said does that cover what are you asking? OR is there something else with DRO I need to do?
What you dont know, you dont know. Or should I say what I dont know! Honestly, as a laymen CNC operator in the world of real Gcode machines and controls, this makes no sense to me that the tool offsets and tool library are 2 separate pages and tools are not associated with an offset until you tell it it is. Hard pill to swallow. How the heck do you keep track of all your tools and what offsets they have??? Seams counterproductive if you ask me. So if your using multiple offsets on a given tool for finishing and roughing why would you do that? I understand adjusting offsets for tool ware but why would you want to use multiple offsets if it's not related to tool ware?tblough wrote: ↑Tue Jun 28, 2022 8:03 amNo, you can't assume that. You have to know how you set up YOUR tooling. You can have multiple offsets for the same tool. On mills this is often used to rough and finish with the same tool. On lathes, multiple offsets are often used with gang tooling. I have a small gang block that is tool 5. The four tools in the block have offsets of 51, 52, 53, and 54.
You must also use D02 to let the CNC know the diamater of the tool, if not G41/42 will not work with tool 02.
