X axis motor trips while running a job <malfunction in the C86ACCp board>
Gary Campbell
Re: X axis motor trips while running a job
Post by Gary Campbell »
Sorry, I forgot about the mini fit connectors as I seldom use them
CNC Depot Modular ATC kits
blksmth
CNC Control System Serial Number: 4063
Post by blksmth »
Everything on hold till I get the new C86ACCP to see if that is the problem.
hennessey
Post by hennessey »
In all of these tests, was it the same *cable* that resulted in lack of negative motion? I know you said that you tested other motors on the x axis port of the c86 and they all exhibited this behavior.
Id be looking at wiring first for sure. My machine did something similar on first or 2nd boot up and turned out i had totally boofed one of the molex connector pin outs.
Gary Campbell
Over the years I've had 2 cables that have had the 2 interior pairs swapped, but those motors would not enable
hennessey
Post by hennessey »
Gary Campbell wrote: Fri Jun 03, 2022 11:02 pm Over the years I've had 2 cables that have had the 2 interior pairs swapped, but those motors would not enable
I believe i had the black and white wires swapped (inner 2 cables bottom row of connector)
EDIT*
correction, the white and brown wires were swapped which was what made my clearpath only want to turn one way
blksmth
Post by blksmth »
Just got the new C86ACCP (that I ordered 5-19-22) wired it up and every thing works as it always had. Was a malfunction in the C86ACCp board. Caused me a lot of headache but I learned some more. One thing I know for sure I wish Centroid would make a similar board and sell to those who are using the Clear Path motors. It would almost be a plug and play system then. No need for a third party gizmo. Centroid and Clear Path are top notch. just my 2 cent worth. Oh by the way I am glad I didn't have a customers high dollar piece of wood down when things went haywire
thanks for reporting back!
blksmth wrote: Tue Jun 07, 2022 10:23 pm Was a malfunction in the C86ACCp board. Caused me a lot of headache but I learned some more.
Where have I heard this before? :D
