Connector and Pin ID?
Fastest1
Post by Fastest1 »
I would rather repin a connector than splice the cables between my Acorn and Logosol drives.
The connector says MXN-15 2695
My guess would be Molex but cant find any such model.
This is an 8 pin connector but I am interested in the pins themselves.
Any help would be great. I seem to see this style connector often.
1st Acorn project. G0704/BDTools/Hoss Conversion De"maching"
Leadshine MX 3660
Repurposed above Acorn (#194) and an Ethernet 1616 to a UMC-10 with an 8 position tool changer.
CNC12 Pro/Digitizing ver 4.64 (1/31/2022)
Re: Connector and Pin ID?
Those are called KK connectors. Also commonly called Waldom connectors. There are a couple different common sizes, identified by the pin pitch.
See http://www.mattmillman.com/info/crimpconnectors/#kk100, or http://www.mattmillman.com/info/crimpconnectors/#kk156
Components are readily available from Digikey and others.
Fastest1
Post by Fastest1 »
Thanks so much, got them ordered
Leadshine MX 3660
Fastest1
Post by Fastest1 »
Those worked out very well.
Originally I was going to put a din rail and terminals to extend the cables.
This turned out much cleaner and the cables will go direct to the Acorn. Much less potential for noise and errors.
Leadshine MX 3660
