Well after changing a bunch of things i cant remember all.
At first i would take care of the wiring with snubbers, EMI Filters and shielded wiring.
Quick check if the PC is the cause, make a backup of CNC 12, get a fresh PC, configure Windows after the manual from Centroid, install CNC12, restore the backup.
If the resends are gone this way try to make a fresh Win 10 install with fresh updates on the old PC, fresh CNC12 install, restore backup. If resends occurs again on the old PC try to work on the network and hardware settings, or discard the PC as not ok for CNC12
Missing Steps in circular interpolation
Re: Missing Steps in circular interpolation
resend errors solution is here. https://centroidcncforum.com/viewtopic.php?f=61&t=1451
