Home All
Home All
If you are using three switches (x, y & z) Home All switches, do you still need another set of three switches for Limit All? I thought that if you used the three switches (x, y, z) with Home All and the soft limits you should not need the Limit All switches.
Re: Home All
No. Home all 3 axes and set your soft travel limits. All you need
CNC Depot Modular ATC kits
