MPG1 encoder error at startup
ashesman
Post by ashesman »
Sometimes when I first turn the machine on I get the above error. I don't use MPG1 encoder, only the wireless MPG. Maybe I need to turn MPG1 off somewhere. Any ideas?
rjtechserv
CNC Control System Serial Number: CNC12-m39-104028
Re: MPG1 encoder error at startup
Post by rjtechserv »
Not sure but I think you could set parameter 348 to zero. Write down the current value if you need to set it back. Try that.
Rob Jackson
RJ Technical Services
The wireless MPG is MPG1, when you use standard PLC logic and set P348=15.
Setting P348=0 would eliminate the error message, but it would prevent the wireless MPG from working.
I see that message all the time on systems with the wireless MPG. I speculate that it is a startup race condition, where CNC12 is looking for data from the wireless MPG, but the MPGClient.exe software has not yet started providing that data.
Perhaps someone from Centroid can clarify, or explain the correct startup sequence to avoid the message.
In the mean time, you can just ignore it. If the MPG works, then there is not really a problem.
ashesman
Post by ashesman »
OK. Thanks for clarifying that. It's not a big deal but would be nice if there were no errors at all at startup!
Maybe starting the mpg client a few seconds before cnc12 in the startup script would work.
Plasma CNC Controller: Yes
ashesman wrote: Tue Dec 21, 2021 1:45 pm OK. Thanks for clarifying that. It's not a big deal but would be nice if there were no errors at all at startup!
Make sure the MPG is on before starting CNC12
ashesman
Post by ashesman »
martyscncgarage wrote: Tue Dec 21, 2021 10:45 pm
I tried tonight. Makes no difference if the wireless MPG is turned on or not before startup. I think its just a Centroid "feature".
Please post a fresh report.
yep, need a fresh report.zip to help.
in general.
F1 Setup, F3 Config, F3 Parameters (pass is 137).
set MPG CNC12 parameter #218= 15 for 4 axis Mills/Routers,
#218=7 for 3 axis Mills/Routers
#218 = 3 for Lathes.
Set MPG CNC12 parameter #348 = 15 (MPG ON) and #349 & #350 = 100 (100 steps per
rev), Set # 411 = 1 (WMPG-4) F10 Save. Exit out of Parameters.
Shut Down and restart CNC12 for new parameters to take effect.
ashesman
Post by ashesman »
Report attached...
Note that the wireless MPG is working 100% fine. Just a warning that comes up at startup. The warning is not causing any harm, I just thought no warnings at all would be nicer.
report_0008DC111213-1214201066_2021-12-26_08-09-57.zip
(3.71 MiB) Downloaded 60 times
thanks for posting the report. i would update to the latest version v4.20.
page 7 https://www.centroidcnc.com/centroid_di ... ctions.pdf
goes over in detail the MPG parameter settings
