KL 5080D4
Iflyb777
CNC Control System Serial Number: 0035FF98C2BC-0421214705
KL 5080D4
Post by Iflyb777 »
Need help on wiring diagram for KL 5080D4 fo Acron
thanks Larry
swissi
Re: KL 5080D4
Post by swissi »
Iflyb777 wrote: Thu Jun 03, 2021 11:45 am Need help on wiring diagram for KL 5080D4 fo Acron
thanks Larry
Just use the "MULTIPLE_LEADSHINE" diagram from this Package
-swissi
Re: KL 5080D4
Just wire up the PUL and DIR per the Leadshine diagram first and see if you get movement. Most time the ENA lines are not needed as the drive is enabled by default. After you get it working them you can wire up the ALM to an input to monitor the drives. Get ONE drive working all by itself first and them move on to the next one and then the third. It's best to not hook them all up at once, get one drive at a time wired and moving, it'll save you many headaches.
Iflyb777
Re: KL 5080D4
Post by Iflyb777 »
