start the wizard and click on the input screen and post a screen shot.noel-nogal wrote: ↑Thu May 20, 2021 12:43 pm Yes i did exactlly what instructions say.
What about the A0 address 10.168.41.3 it say cnc12 automatically identify it but where i can see that addres? Or do i have to replace the ip address in the ethernet adapter, now it is 10.168.41.1 wich is for the acorn
Acorn controller card question
Re: Acorn controller card question
Shut the system down, Acorn, Ether1616, switch etc.
Start the CNCPC and catch up on your Windows updates, make sure you have them all updated.
When that is done, power off the PC.
Start the Ethernet switch, Acorn, Ether1616
Then power up the PC
Start CNC12. You should get a message that Ether1616 was detected, Acknowledge the message.
Once CNC12 has fully started, go into the Wizard Input screen. Ether1616 should be available to populate with inputs.
Post a fresh report when you have done all the above.
The report shows a lot of communication errors, such as
"452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270" and
"945 PC requested resend # 1"
These should be resolved before adding the extra complexity of the ETH1616. The first thing to try is removing the Ethernet cables from the cable tracks and away from power wires.
Sorry Matt,
I didn't see those until I got to my desktop.
Noel, this is from your error log (F7 Utility, F9 Logs, F1 Errors)
(1) 05-19-2021 16:57:12 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(4) 05-19-2021 16:57:20 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 05-19-2021 16:57:20 9033 Reset Initiated, Press Reset to Clear
(4) 05-19-2021 16:58:00 4032 Reset Cleared
(1) 05-19-2021 16:58:04 204 Exiting CNC...Normal Exit (66)
(1) 05-19-2021 16:58:48 199 CNC Started
(4) 05-19-2021 16:58:52 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 05-19-2021 16:58:56 CNC12 Acorn Router v4.64
(4) 05-19-2021 16:58:56 9033 Reset Initiated, Press Reset to Clear
(4) 05-19-2021 16:59:08 4032 Reset Cleared
(1) 05-19-2021 17:00:28 204 Exiting CNC...Normal Exit (66)
(1) 05-19-2021 17:01:48 199 CNC Started
(4) 05-19-2021 17:01:52 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 05-19-2021 17:01:55 CNC12 Acorn Router v4.64
(4) 05-19-2021 17:01:55 9033 Reset Initiated, Press Reset to Clear
(4) 05-19-2021 17:02:03 4032 Reset Cleared
(1) 05-19-2021 17:06:55 204 Exiting CNC...Normal Exit (66)
(1) 05-19-2021 17:07:10 199 CNC Started
(4) 05-19-2021 17:07:14 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 05-19-2021 17:07:19 CNC12 Acorn Router v4.64
(4) 05-19-2021 17:07:19 9033 Reset Initiated, Press Reset to Clear
(4) 05-19-2021 17:07:51 4032 Reset Cleared
(1) 05-19-2021 17:09:59 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(1) 05-19-2021 17:10:33 204 Exiting CNC...Normal Exit (66)
(1) 05-19-2021 17:11:11 199 CNC Started
(1) 05-19-2021 17:14:09 102 Error initializing CPU...cannot continue.
(1) 05-19-2021 17:14:11 201 Exiting CNC due to a known error (63)
(1) 05-20-2021 8:07:47 199 CNC Started
(1) 05-20-2021 8:07:56 CNC12 Acorn Router v4.64
(4) 05-20-2021 8:07:56 9033 Reset Initiated, Press Reset to Clear
(4) 05-20-2021 8:09:23 4032 Reset Cleared
(1) 05-20-2021 8:18:37 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
(4) 05-20-2021 8:18:41 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 05-20-2021 8:18:41 9033 Reset Initiated, Press Reset to Clear
(4) 05-20-2021 8:19:42 945 PC requested resend # 1
(1) 05-20-2021 8:20:30 204 Exiting CNC...Normal Exit (66)
(1) 05-20-2021 8:20:57 199 CNC Started
(4) 05-20-2021 8:21:01 9033 Reset Initiated, Press Reset to Clear
(1) 05-20-2021 8:21:06 CNC12 Acorn Router v4.64
(4) 05-20-2021 8:21:06 9039 Software Exited, Cycle E-Stop/Reset to Continue
(4) 05-20-2021 8:21:06 9033 Reset Initiated, Press Reset to Clear
(4) 05-20-2021 8:21:14 945 PC requested resend # 1
(4) 05-20-2021 8:21:18 945 PC requested resend # 2
(4) 05-20-2021 8:21:37 945 PC requested resend # 3
(4) 05-20-2021 8:21:44 945 PC requested resend # 4
(4) 05-20-2021 8:23:07 4032 Reset Cleared
(4) 05-20-2021 8:23:10 945 PC requested resend # 5
(1) 05-20-2021 8:24:27 Creating report...
- CNC Control System Serial Number: (2669)
My cncpc detected the ether1616 card, the problem was windows update, it has been reset and updated, the first time i turn everything back on the 1616 card showed up onthe wizard window.
Mr. Marty
i have my ether1616 card already working now, i have plenty of inputs and outputs, can i use now some of this output tocontrol the ATC and save my 4th axis? i had my 4th axis for ATC before adding the 1616 card, what you suggest me
Ether1616 provides more inputs and outputs. It does not provide for another Axis.noel-nogal wrote: ↑Thu May 27, 2021 11:27 am Mr. Marty
i am watching this video, but idon't know where is the plc program he is talking about, where i can find it?
it is the Acorn.SRC file. It can be edited and then must be compiled.noel-nogal wrote: ↑Fri May 28, 2021 11:49 am i am watching this video, but idon't know where is the plc program he is talking about, where i can find it?
Once compiled it becomes the mpu.plc file which is NOT editable.
Info in the PLC Programming manual.
Be sure you know what you are doing....otherwise hire someone like Marc Leonard (cncsnw) or Centroid to do your PLC work.
Actually we paid one hour tech support to centroid friday but it was late in and could not get contact with them, hope monday we be able to contact someone from centroid.
Where i can get in contact with Marc Leonard? Just in case i need to, the only thing i need to get this job done is the automatic tool changer but yes plc it is for someone else.
