Pulse in setup
Re: Pulse in setup
martyscncgarage wrote: Mon Apr 12, 2021 11:22 am Go into MDI and do a G0A360 the rotary axis should turn one full revolution
Guessing from the photo of your rotary table, you should have your A-axis configured so that the G0 A360 command causes the table to rotate clockwise when viewed from the chuck side.
viewtopic.php?f=64&t=3638
usinart
Re: Pulse in setup
Post by usinart »
Thanks Marty
As mention earlier without limit switch on the A axes I should modified a cncn.hom or something like that .
I did by adding m26/ A
But each time I making some modification and re home the g92 a.... it adding by it self .
How to get of those because no limit switch on the A axe.
Alain
report_E415F6F138CC-1119204064_2021-04-19_16-21-11.zip
(639.75 KiB) Downloaded 71 times
Plasma CNC Controller: Yes
Re: Pulse in setup
usinaet wrote: Mon Apr 19, 2021 4:26 pm Thanks Marty
Alain
You need to go into the Wizard, homing and travel and check the I will create my own Home file do not OVERWRITE the .hom file.
Then when you make changes in the Wizard, it will not create the .hom file (It does that unless you tick the radio button not to overwrite it)
